To integrate an ExtremeXOS switch in an LDAP environment, a
          RADIUS server must be configured to communicate with the LDAP
        database. The following components are required to install the access control
          solution:
        - Linux server with Linux Red Hat 4.0
        - FreeRADIUS 1.1.x
        - OpenLDAP 2.3.x
        - Extreme Networks switches
        - Windows 7/Windows 8 clients
      To configure Universal Port for use in an LDAP environment,
use the following procedure:
        Install and configure a RADIUS server on an existing Linux
          server as described in Installing and Testing the FreeRADIUS Server.
        Install and configure OpenLDAP as described later in
this section.
        Add vendor specific attributes to the RADIUS and LDAP
          servers as described in Installing and Testing the FreeRADIUS Server and later in this
          section.
        Configure the edge switches as described in this guide.
        Configure each supplicant as described in Configuring a Windows 7/Windows 8 Supplicant for 802.1X Authentication.
    For complete instructions on setting up an LDAP
      server, see the product documentation for the LDAP server.
